Does anyone sandpaper the rotors when swapping pads?
Directions on the box of new Hawk HPS pads: "If disc does not need resurfacing then contamination from the previous brake pads must be removed. Sand disc with 130 grit sandpaper using moderated pressure..."
I figured the bedding process would take care of the old pad material...
Never done it...just bed in the new pads and called it a day.
That said, if you can't help yourself, use garnet paper, not regular sand paper. The aluminum oxide in regular sandpaper will cause issues IIRC.
i've never done it, but i can see why. I just bed on top and hope the new pad is stronger...
...then the old one. I clean the disc thoroughly with brake cleaner.
but plan on some pedal vibration till you bed the new pads in.
