Does SEL do the "exact" same thing as a boost controller?
Currently I'm running stock fueling w/ MBC in parallel & a TCD. I have my MBC cranked to ~20 then I dialed it down with SEL to ~85% which puts boost at ~16 and I fvcking swear that the ramp is smoother than just setting the mbc to ~16 and SEL at 100%. I am noticing this especially under high load, low RPM like ~3000 in 6th WOT.
But it also might be the crack. :-)
I can only assume that increasing/decreasing boost whether it be through a controller or SEL does adjust AFR.
To go through exactly what happened, I logged 02's this past weekend which peaked at .86 so I decreased SEL by ~3% which put my 02's in the .875 range.
So they do, in fact, adjust AFR in the same respect. No?
The SEL adaption channel is going to scale down the specified engine load (SEL) which is an axis on those maps. So by changing the load, you are changing where the ECU looks in those maps for its data values for boost, fuel, timing, etc...
-Dave Pramanik
-Dave Pramanik
more agressive boost ramp up demanding more fuel or......
does SEL have no effect on WOT boost levels only the agressiveness or speed of the onset of boost (IE - LOAD)
still learning more about LW but curious about this...
don't get me wrong, I get the exact same thing. But I'm talking about parking, analyzing data for ~20 min, then relogging and getting consistant number changes from what they were in previous runs, logs with nothing else changed but SEL or a quick turn of the mbc.
The numbers ARE changing.
