doing rear rotors/pads without the special tool
Old 12-02-2005, 10:05 AM
New Member
mjb924S's Avatar
Default doing rear rotors/pads without the special tool
I just posted a how-to on the brake forum for retracting the rear caliper pistons without the expensive and not-available-locally special tool. The only non-standard tool required is one of those cheap piston retracting cubes available at Pep Boys or wherever.
Old 12-02-2005, 10:08 AM
Senior Member
DeutschDriver's Avatar
Default the cube sucks ***...
i managed to bust one in about 2 seconds. just borrow / rent / buy the tool and you'll be much happier
where are you located? i'll loan you mine if your local.
Old 12-02-2005, 10:09 AM
lemieux@curbside's Avatar
isn't that "the special tool " ?
Old 12-02-2005, 10:14 AM
WindyCityS4's Avatar
Default I don't consider $40 to be an expensive tool. But it is always good to have low tech....
option
JasonS4+Festicle's Avatar
ditto - I hate that little cube thing - I'd wait to do the job to get the better tool.
Old 12-02-2005, 10:16 AM
New Member
mjb924S's Avatar
Default Re: isn't that "the special tool " ?
No, the special tool consists of a plate and concentric shafts, one for pushing the piston, one for turning it. Costs something like $60-$120, has to be ordered, can't drive out on a Sunday and pick one up.
Old 12-02-2005, 10:19 AM
Christian (Stage Ow)'s Avatar
3rd. And if you try to use pliers, you chew up the dust boot. Buy/rent the tool.
Old 12-02-2005, 10:20 AM
Default I bought mine for $35 from Autozone - call around to some places that rent tools.......
You might find one.
The tool I bought was one I rented from Autozone. It was new in the package when I "rented" it. I called after using it and asked if I could just keep it since it was soooo much better than the little cube.
Anyway, they kept my deposit of $35 and that was it.<ul><li><a href="http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40732">http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40732</a</li></ul>
EdyJun's Avatar
Why not rent one from autozone and make the job easy?
Old 12-02-2005, 10:21 AM
But yours broke!!
Quick Reply: doing rear rotors/pads without the special tool
