Down to these: Southbend Stage 4 FE or Clutch Masters stage 4...
Old 12-18-2008, 06:36 AM
  #11
Dr. Jekyll's Avatar
you have a 6 puck stage 4 with an unmodified fidanza?
Old 12-18-2008, 06:52 AM
  #12
KillA6's Avatar
Default I had issues with my CM /LWFW ( fidenza. ) I would go SB out of your choices.I went with VAST Hybrid
No issues so far. Stage 3- ,I drag it ect.
Old 12-18-2008, 07:28 AM
  #13
extrabolts's Avatar
Default I am happy with my clutchmasters stg 4 clutch + FW setup
If you see stories of them failing, just remember that this is a wear item and very prone to "idiot failure." If you drop any clutch repeatedly from 6k when street racing every weekend, it will not matter what clutch you have, the life will be limited.
Clutchmasters makes good products and has been around forever. They used to sponsor one of my drag cars, and I had nothing but good experiences with their products. There are other good clutches on the market also, I'm not advocating clutchmasters over others, just saying take the negative comments with a hint of skepticism.
Old 12-18-2008, 08:21 AM
  #14
Z-Tuned (Alex)'s Avatar
Default The south bend FE with RS4 pressure plate has awesome driveability, near stock. But I don't think
it will hold the power you're looking for...
Old 12-18-2008, 08:22 AM
  #15
Yup.
Old 12-18-2008, 09:23 AM
  #16
Former Vendor
SIMPPLY @ WMS's Avatar
Default hahah make sure you buy the right CM clutch setup .
We have setups that can hold power.
Old 12-18-2008, 09:57 AM
  #17
B5QShip's Avatar
Default Fvck the SAC/RS4 PP, nothing but problems!!! Consider a new SPEC setup or the non-SAC Sachs PP
the latter needs a special adapter to work properly...I know Al@CPT has installed several of these. Personally I didn't like the feel of the clutchmasters setup I tried, but take that fwiw.
Old 12-18-2008, 12:18 PM
  #18
~DonQPremiumTequila~'s Avatar
yes
Old 12-18-2008, 01:07 PM
  #19
Dr. Jekyll's Avatar
Default Not sure how that's possible. Everything I've seen says there is or will be (once it wears)
clearance issues between the fw bolts and the friction disk.
You can get other fw's to work, but you need to counter sink the fw bolt holes in the fw.<ul><li><a href="https://forums.audiworld.com/s4/msgs/2170198.phtml">https://forums.audiworld.com/s4/msgs/2170198.phtml</a></li></ul>
Old 12-18-2008, 01:20 PM
  #20
Junior Member
lulz's Avatar
i am happy with my clutchmasters stage 3/4 hybrid that i got from ultrarev, they are the cheapest
Quick Reply: Down to these: Southbend Stage 4 FE or Clutch Masters stage 4...
