Drivers door opens half way with one handle pull, fully open on second attempt.
Any thoughts?
I haven't taken off the inside of the door yet to check the operation. I replaced a ballast today and figured I would call the car fixed for one day before before I say something is officially broken again.
weird...this _just_ started happening to me on the driver's side.
for me it's only intermittent, although i can make it do it every time if i try.
ill be following this thread.....
Not sure if this is the same issue at all but here is what i ran into:
i went to open my drivers door from the inside last year and it made a snap and then mine was doing the same thing but only from the inside handle. I took it apart and found the broken piece in with the spring mechanism. I just removed the broken part and was going to order a replcement, but i found that after the broken spring assembely was out of the way, it worked perfect again. When i shut the door, the handle goes back in tight, but when the door is open, it has some slack. Something that ive decided i can live with and i forgot about until readin your post.
Anyway, good luck
Anyway, good luck
Thats exactly how it is for me. A quick open and it sticks every time. and like 25-75% of the other time it sticks. (just starting happening, so I have limited data)
I also have the broken spring issue on the inside, never caused an issue getting out for me. Looks like I'll be spending easter alone this year... I'll take apart the door and try to figure this out for the both of us. If it's any thing like the handle's on a 2002 Impalla it should be an easy fix.
i'm not gonna get a chance to look at it this weekend or anything, but i will at some point.
this would be an awesome place to post a link to how to remove the door panel without messing everything up..... (i'll go see if i can find one, but if you have one bookmarked..please post!)
thanks.
I get the same thing on the outside getting in, worse when cold and the handle is a little slack on the inside too. I haven't been too bothered by it but if there is a post on how to disassemble the door to see inside that would be great.
Lots of wd-40 into the lock mechanism. Lossens things up. Havent had to take teh lock apart.
I grabbed a can of spray lithium grease. I attacked from inside the latch section as well as into the lock.
I think that giving the latch section the most attention is best. I used quite a lot of the stuff...
At any rate, the problem is gone for me at the moment. -It's been good for over a year since.
Hope it helps.
Hope it helps.
Kingttr
12-05-2006 08:47 AM
StealthB4
11-25-2005 08:53 PM
85-4kq-girl
02-11-2005 01:06 PM
