'Droning' sound coming from front between 35-40 mph...
I used to hear this in the rear, and it was my rear wheel bearings. Did the turn right/turn left and sound went away for those, and that helped confirm that. Had them replaced. All is well.
Similar sound now coming from front, but the turn right/turn left 'test' isn't so conclusive. Suggestions of what it would be if not front wheel bearings? Or, better yet, how can I determine for sure (beside swapping them) that it is the front wheel bearings?
Thanx in advance for any help!
Also, I would *think* that tire noise would get louder, not just be between 35-40 mph, and not kinda 'go away'.
<center><img src="http://pictureposter.audiworld.com/47960/s4_93octane_yarrowsport.jpg"></center><p>
setup was k04/16s running awe ko4 mbox flow straightener code
the logs you see are with no tweeks
Mark P later pulled some 7% secondary, but after some logging I found it was running way to lean
Have since put secondary back to 100% and added 2% primary and 2 degrees of timing
Can't get ecux working after installed lemmi - but after making changes and doing stop watch FATS runs (i will get real data) the old settings (93% secondary) was getting a 4.9 second FATS time (this was done with ECUX - it was 95 degrees brutal humidity and .2 seconds for the oversized wheels) - the new settings (+2% primary +2 timing) - was getting 4.5 seconds (i figure 4.3 adjusting for the tire size) - normal weather this should be high 3s
My 2 cents is that a 4th gear FATS time is where the k16s would show the biggest gains versus plain KO4s - my highway driving and one track day on them makes me say this
Leester
03-31-2005 11:39 AM
Kinetic0510
04-05-2004 09:38 AM
CrazyINP-12V Ivan
12-01-2000 08:36 PM
