DTC Help.
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 H
Component: 2.7l V6/5VT G 0003
Coding: 06711
Shop #: WSC 06435
VCID: 2F66C14CC79B
1 Fault Found:
18030 - Engine Coolant Temp Signal: Implausible Signal
P1622 - 35-10 - - - Intermittent
Readiness: 0010 0101
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 R
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 06435
VCID: 3A70E0180CD9
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-00 - Open or Short to Plus
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06435
VCID: E5CAE36455E7
1 Fault Found:
00776 - Level Control System Sensor; Left Front (G78)
31-00 - Open or Short to Ground
Coding: 06711
Shop #: WSC 06435
VCID: 2F66C14CC79B
1 Fault Found:
Coding: 02264
Shop #: WSC 06435
VCID: 3A70E0180CD9
1 Fault Found:
Coding: 00012
Shop #: WSC 06435
VCID: E5CAE36455E7
1 Fault Found:
frustrating..
Hmm. I think there are at least two temp sensors for the coolant, if not more. I can't recall which one reads to the instrument cluster though. Maybe you've got some bad wiring causing a short?
Are you having noticable symptoms or is it just the check engine light?
I'm getting 17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat) on VAG and I get HORRIBLE fuel economy right now (15MPG avg according to Fuelly). I don't blame it on the cooling system but I could see the implications of the cooling system causing the car to really guzzle gas before warming up. I'm ordering a new coolant sensor just to be sure.
Is the gauge completely dead or does it take a long time to warm up??
Try pulling the temp readings via the HVAC system. What is your exact model and year? Temp sensor G2/G62 and F18/F54 are on the Right(passenger) side on the rear water pipe. Are you sure you changed the correct one? What is the temp of the air at the dash vents? Should be 120-140 degree if the car is at full temp. G2 turns off AC at 120F and G42 at 116F reduces Air Charge Pressure.
born_slippy
04-05-2017 04:28 PM
Asgor
VAG-COM Discussion
03-20-2007 07:29 AM
Djole
Audi 100 / A6 (C4 Platform)
9
09-26-2005 06:13 PM
