DTC help (TIA)
DTC help (TIA)
What's your take on this?
19 DTCs Found:
16712 - Knock Sensor 1 (G61): Signal too High
35-10 - - - Intermittent
16524 - O2S B1 S2: No Activity
17931 - Crash Signal from Airbag Controller: Implausible Signal
16684 - Random/Multiple Cylinder Misfire Detected
16685 - Cylinder 1 Misfire Detected
16804 - Catalyst System Efficiency Below Threshold (Bank 1)
35-00 - -
16890 - Idle Control System: RPM too Low
17633 - Fuel Injector for Cyl 1 (N30): Short to Ground
17637 - Fuel Injector for Cyl 5 (N83): Short to Ground
17635 - Fuel Injector for Cyl 3 (N32): Short to Ground
17638 - Fuel Injector for Cyl 6 (N84): Short to Ground
17833 - EVAP Purge Valve (N80): Short to Ground
17880 - EVAP Leak Detection Pump: Short Circuit to Ground
17843 - Secondary Air Pump Relay (J299): Short to Ground
17829 - Sec. Air Inj. Valve (N112): Short to Ground
17636 - Fuel Injector for Cyl 4 (N33): Short to Ground
17923 - Intake Manifold Valve (N156): Short to Ground
17634 - Fuel Injector for Cyl 2 (N31): Short to GroundNo DTCs Found
17525 - O2S Heating Circuit: B1 S2: Short to Ground
thanks
19 DTCs Found:
35-00 - -
thanks
None
these are actually codes from my gf's jetta I was just curious what you guys thought because some of you really know your stuff. the engine control system is atleast similar so I thought you might have some input.
Cipher5170
05-24-2003 12:12 PM
