Dyno day #2 - Dyno graphs With ECUx charts
I did four runs at the local AWD dyno. These were the results. Please have a close look at the timing and AFR / priO2 graphs. Let me know what you think! Mods in sig
The full spreadsheet export is located here:
<a href="http://www.paulben.net/postings/Dyno2/Dyno2-stg3.htm"> http://www.paulben.net/postings/Dyno2/Dyno2-stg3.htm</a>
Temp: 56F
Date: Jan 16, 2007
The two dyno graphs have todays run as well as my last run in November at Stg 2.
Torque 382
Power 330
<img src="http://www.paulben.net/postings/dyno2/Dyno2-PT.jpg">
Torque and AFR
<img src="http://www.paulben.net/postings/dyno2/Dyno2-AFR.jpg">
================== ECUx graphs ================
Red=Pull #1
Magenta=Pull #2
Dark Blue #3
Blue=Pull #4
<img src="http://www.paulben.net/postings/dyno2/boostPSI.gif">
<img src="http://www.paulben.net/postings/dyno2/boostvalve.gif">
<img src="http://www.paulben.net/postings/dyno2/IAT.gif">
<img src="http://www.paulben.net/postings/dyno2/MAF.gif">
<img src="http://www.paulben.net/postings/dyno2/InjectorDutyCycle.gif">
<img src="http://www.paulben.net/postings/dyno2/InjectorOnTime.gif">
<img src="http://www.paulben.net/postings/dyno2/knockv.gif">
<img src="http://www.paulben.net/postings/dyno2/timingOverall.gif">
<img src="http://www.paulben.net/postings/dyno2/timingTard.gif">
<img src="http://www.paulben.net/postings/dyno2/engineLoad.gif">
<img src="http://www.paulben.net/postings/dyno2/pedalVThrottle.gif">
<img src="http://www.paulben.net/postings/dyno2/AFRDesired.gif">
<img src="http://www.paulben.net/postings/dyno2/primaryo2v.gif">
Temp: 56F
Date: Jan 16, 2007
Torque 382
Power 330
Torque and AFR
Red=Pull #1
Magenta=Pull #2
Dark Blue #3
Blue=Pull #4
of 22 psi in the second run. Which run does the dyno sheet correspond with?
I was also expecting and trying to see the throttle cut.
I need help! I have to find all that missing power!
load. Everything is fulled back RE fueling as my injectors are huge. It runs lean now! Unfortunately it still codes as rich when warming up. I am thinking about adding to primary.
What do you think of the O2 / AFR charts? MBC is set to 19. The AWE code doesn't let it exceed 19 except in that nasty spike.
I have a TCD that I can put on, maybe put it up to 21 and taper to 18?
input?
input?
what size is your maf again? Whats your intake setup? which code are you running? Your desired AFR should setting down quicker. To do this your MAF reading must hit at least 190g/sec before 4k.
<img src="http://i2.photobucket.com/albums/y15/blk01s4/fats_01_16_07/FATS_1_16_07-16.gif">
<img src="http://i2.photobucket.com/albums/y15/blk01s4/fats_01_16_07/FATS_1_16_07-17.gif">
<img src="http://i2.photobucket.com/albums/y15/blk01s4/fats_01_16_07/FATS_1_16_07-4.gif">
