Dyno results: huge lean spike at 3500 RPM with GIAC stage 3- chip
Old 03-31-2007, 01:10 PM
AudiForYou's 2.7T's Avatar
Default Dyno results: huge lean spike at 3500 RPM with GIAC stage 3- chip
I had the car dynoed again today. This time boost and air-fuel ratio was measured.
First graph shows HP and torque, second graph shows boost and air-fuel ratio.
<img src="http://pictureposter.audiworld.com/66538/dyno_1.jpg">
<img src="http://pictureposter.audiworld.com/66538/dyno_2.jpg">
See that huge spike in the air-fuel ratio at 3500 RPM, around 18 parts air for 1 part fuel? That's a lot! On another run it spiked all the way up to 22. That's dangerously high, as far as I know...
What's up with that?
It's not a misfire, because there is no power dip in the first graph.
The ratio was measured at the exhaust pipe. I don't think there anything pumping oxygen into the exhaust when the car is fully warmed up, is there?
So I think the ECU programming is to blame.
Any experiences or comments? Suggestions? Thanks.
Old 03-31-2007, 01:24 PM
ErikS4's Avatar
What injectors?
Old 03-31-2007, 01:33 PM
ErikS4's Avatar
Reading your sig - no mention of injectors - I'd say that's the problem. Just a 5-bar won't cut it.
Old 03-31-2007, 02:07 PM
AudiWorld Expert
nyet's Avatar
got any logs?
Old 03-31-2007, 02:15 PM
rktskicar's Avatar
Default Somethings not right. My GIAC 3- had a max of 13.5 AFR, min 11.4 AFR on dyno. Are you sure you
have a true 5 bar FPR (not crushed 4 bar).?
Bruce
Old 03-31-2007, 03:17 PM
According to GIAC, stage 3- chip is designed for stock injectors. Maybe they're just clogged?
Old 03-31-2007, 03:18 PM
Yes, it's a real 5 bar, from AWE Tuning
Old 03-31-2007, 03:47 PM
Member
addìct's Avatar
If that's wheel horsepower, that's really optimistic
Old 03-31-2007, 04:12 PM
Why? 289 whp seems about right. It was optimistic at waterfest last year when it measured 325 whp.
Old 03-31-2007, 04:20 PM
rktskicar's Avatar
Default 2nd. My GIAC 3- was around 300 WHP.
<center><img src="http://pictureposter.audiworld.com/44443/asp_stage_3_vs_giac_3-_vs_giac-x_vs_stock_0_031407-adj.jpg"></center><p>
Quick Reply: Dyno results: huge lean spike at 3500 RPM with GIAC stage 3- chip
