E-Code headlight housing...moisture leak...help!!!
I just picked up my car from the dealership and they use one of those "spotless" washes to clean the cars. Well my passenger side E-Code headlight housing now has all the moisture in it...any way to fix this (ie - reseal it, etc?) Any help you can provide would be great, thanks.
most likely it came un-snapped and just needs to be closed again....
If you installed them, you know what I'm talking about.
The headlight housing has a little hole at the bottom. That should NOT be sealed. It is for moisture to escape. Just let the headlight dry. Best if you take a hair dryer and warm up, not heat up, the headlight housing so that the water can evaporate and leave. If you want to spped it up, open the seal of the Xenon bulb and loosen the bulb, do not take it out, just enough to let air and moisture escape. Do not let the dealer wash the car again... However, if the headlight is under water (not moisture), go back to the dealer and have them replace the headlight at their cost.
Stroget
Q5/SQ5 MKI (8R) Discussion
12
05-13-2021 11:56 AM
SCarGo02
12-29-2006 07:31 PM
Vegito@BostonAudi
01-16-2003 05:57 AM
