ECUx BT: Having trouble with properties file.
I've read the help section on ECUx and I'm still suck at starting a new ECU group file. When I try it gives me VAG100 - VAG163. This is where I'm stuck as I don't know what I'm supposed to select there. Any help you all can give me would be appreciated.
have the wrong property file. The easiest way to test is by logging with the key in on position, but engine off.
You can choose the property file without the cable plugged in, but what good does that do you if you haven't tested to make sure it's the correct one?
VR_Life
10-11-2006 02:10 PM
CWTech
12-09-2003 04:38 AM
RobC
06-20-2002 09:23 PM
