Which ECUx poperty file to use on B Box?
Did logs for the first time yesterday with ECUx using 121 prop file (A-box). But the logs were weird. 0 actual boost and ~500 requested (thoughout the whole pull)?!? Today I checked for boost leaks and logged 115 with just VAG /w no probs.
I STFA and looked at the S4 wiki. B-box didn't have a ECUx prop file listed.
What prop file are other B-box'es using?
2000 TIP /w APR v5 Stg 2+ code
AudiWorld Expert
SEarching the forums for VAG121 will turn up the full list, FYI. Here's the snip of the B5 S4 profiles. I never noticed that there was an A6 one listed in there - I only noted the 6spds and assumed the 2nd entry for each was the corresponding Tip... Sounds like you should contact APR on this one (and/or just try these 4 profiles and see if any of them work)...
VAG120
Audi S4 NA MY2001 2.7T 6-spd Manual 8D0907551M S0001/S0002
Audi S4 NA MY2001 2.7T Tiptronic 8D0907551L S0001
VAG121
Audi S4 NA MY2000 2.7T 8D0907551A S0003
Audi A6 NA MY2000 2.7T 6-spd 4B0907551K
VAG122
Audi S4 NA MY2002 2.7T 8D0907551T S0003
Audi S4 NA MY2002 2.7T Tip 8D0907551AA S0003
VAG123
Audi S4 NA MY2001 2.7T Tiptronic 8D0907551J S0003
Audi S4 NA MY2001 2.7T 6spd Manual 8D0907551H S0003
VAG120
VAG121
VAG122
VAG123
VAG121 *kinda* works, but looking at these boost logs it doesn't look right.
<a href="http://mcostello.fusioncentral.com/logs/">logs here</a>
Actual and Desired aren't even showing up on Mark P's charts (too small), but take a look at the CSV and a tiny bit boost is being requested.
Tonight I ran some logs with plain old VAG and boost looked much better, I'll post graphs soon. My question is whats going on with ECUx?
StreetCrawler(Cole)
12-06-2007 11:26 PM
I AM 2ks4
04-15-2004 04:41 PM
S4zero8
21
03-18-2004 01:31 PM
