Edit* Long story about my car not moving. With details. New wheel color for the day crowd (BBS).
Old 07-11-2007, 05:45 AM
Dr.Duct_Mossburg's Avatar
Default Edit* Long story about my car not moving. With details. New wheel color for the day crowd (BBS).
<center><img src="http://pictureposter.audiworld.com/99468/dscf0051.jpg"></center><p>^^^ this pic is NOT what my car currently looks like.^^ Read below for more info.
Engrish content.
Ok, as most of you know about a year ago i wrecked my car.
After I wrekced it the car drove fine. If i were blind, i wouldnt of known the car was wrecked (great analogy huh ?).
After about a year, i get all of the motor parts done. (pulleys, belts, oil pan, so on and so on.
Yesterday i cranked her up.. she started up first try, no problems. Im thinking wow what a champ. I go to move it. Put it in reverse, she doesnt move ??? Put it in first, she doesnt move ?? Second ? same thing. So i turn it off, scratch my head. Turn it back on, and repeatthe process. Only this time i notice that rpms and and speedometer go up ?? the car sounds like its driving. No sounds of axles being broken, drive shafts being broken, or gears grinding ??
* Refferance the pic. I know what this sounds like* lol
Possible things i can think of.
The entire core support, intercooler, and bi pipe is off of the car. So none of those sensors are plugged in. Could this cause it ??
The Airbag lights have not been reset since the accident.
the car goes in and out of gear with ease. The trans and clutch are both only 10k miles old. Done by the stealership under warranty. the rear diff and drive shafts were replaced 7k miles ago.
WTF ????
What controls the mph reading on the car, and how does it move when the car doesnt move ???
TIA for your help everyone..
Good stuff...
new wheels scheme. Hate it or love it. I love it.<ul><li><a href="http://&lt;a%20href="http://photobucket.com"%20target="_blank"&gt;&lt;img%20sr c="http://i71.photobucket.com/albums/i128/Mossburg031/untitled-4.jpg"%20border="0"%20alt="Photo%20Sharing%20and%2 0Video%20Hosting%20at%20Photobucket"&gt;&l
Old 07-11-2007, 05:54 AM
AVANT S4 KING's Avatar
Default ysati
<img src="http://i71.photobucket.com/albums/i128/Mossburg031/untitled-4.jpg" />
And YSATCC (CC = color choice)
Old 07-11-2007, 05:56 AM
Junior Member
B5QShip | CFDQ's Avatar
Default uh, you started the car with the throttle body taking in ambient air?!
put some sand through there as well?
Old 07-11-2007, 06:00 AM
AudiWorld Expert
Mark P's Avatar
Default maybe one of the diff's is toast, or you forgot to connect one of the drive shafts...
The speed sensor should be on the output shaft of the trany, so that would suggest the clutch is not slipping. So, it would seem that the issue is somewhere between the input shaft on the tranny and the wheels. If none of the axles were connected to the tranny (ie missing all bolts), I could see this happening. If only 1 wasn't, I'd expect the diffs (quattro) to still move the car...
I'd try again and have someone check to see if any of the 3 outputs from the tranny are turning (but not turning the axles due to missing bolts), and then try again on jack stands to see if any of the wheels move, and also to see if any of the 3 outputs from the tranny are turning....
Old 07-11-2007, 06:02 AM
Junior Member
Rolf's Avatar
Default big 2nd!? first thing I thought. How can you start the car
with no bi-pipe, IC's, radiator!? thats like the worlds biggest boost leak. If I were your car I wouldnt want to drive either!!!!
Old 07-11-2007, 06:05 AM
I drove the car for about 6 months after the shafts and diff were replaced.
Old 07-11-2007, 06:07 AM
Default I had to move the car. Its a steep incline into the garage.
It was about to start raining. 6 people wouldnt be able to push this tank up the hill.
Moving the car 20 feet without the radiator isnt going to kill the car.
Old 07-11-2007, 06:08 AM
Junior Member
Rolf's Avatar
I guess your car thought it would it didnt want to move for you. did it ever move?
Old 07-11-2007, 06:12 AM
Junior Member
cars in pieces belong in garages, not at the bottom of hills.
Old 07-11-2007, 06:15 AM
AudiWorld Expert
Mark P's Avatar
Default interesting, but I'd still try the above based on the speed sensor being in the tranny...
so the internals of the tranny must be moving if the speedo is registering (assuming the speed sensor is properly located)
Quick Reply: Edit* Long story about my car not moving. With details. New wheel color for the day crowd (BBS).
