EGT Questions...
1. How does the VAG tool measure EGT's? Through the ECU?
2. Is there a separate sensor that can be tapped into for measurement via an outside gauge?
3. For those of you who have EGT gauges installed, where did you place the sensor (manifold, on top part of the DP?)
4. Can the manifolds be accessed from under the hood for sensor placement?
5. Any special wiring harnesses that need to be tapped?
6. Anything else I'm missing?
1)YES
2)yes you can tap into the EGT sensor but you need make sure it won't screw up the resistance it's sending
3) not I
4) Passenger side manifold I believe but you can easily get to it and see it.
3) not I
balancing the values for the EGT sensors(black modules on the back of the manifold) from each bank...I guess if you had a voltage sheet for the egts you could setup up a gauge to show the temp values!
prjct337
01-16-2007 10:52 AM
pureroundcircle
05-02-2005 10:20 AM
BlackS4tt (Josh)
11-01-2004 11:31 AM
