engine part numbers inside, i figure i post these in case anyone needs them still incomplete
ones w/ "?" or comments in front are notes, when i was doing my rebuild i found it to be ALOT cheaper to order through genuineaudiparts.com than from some of the sites that offer these items as a kit.
? 077105425E rod bolts (need 12)
? main bolts
078105701NGLB rod bearings (need 6 sets)
057198491 main bearings
2 or 4? 078198421 thrust bearings (need 2)
? wrist pins (need 6)
? N 90558301 piston snap ring (need 12)
06B198151B piston rings (need 6)
078103385K head bolts (need 16)
078103383K head gasket (need 2)
038103085E front crank seal
078115189H front seal gasket
026103085D camshaft seal (need 4)
078103113E cam plugs (need 2)
058198217 cam adjuster gasket (need 2)
078129717N intake manifold gasket
078198025 valve cover gasket (need 2)
N 90500101 crank lock oring
N90613201 oil pump oring (need 3)
078115105D oil pump
028117070b oil cooler oring
078145777C Driver side oil feed line
078145778B Pass side oil feed line
078145735E driver side oil drain line
078145736D pass side oil drain line
078121951A block coolant drain bolt 6mm
N 90041102 block coolant drain bolt oring
N 90560701 Coolant pipe oring to back of head (need 2)
N 90380002 coolant pipe oring to back of waterpump pass side
N 90365302 coolant pipe oring to front line driver side
N 90560701 coolant pipe oring to pipe going to back of head
? exhaust manifold to head Stud
078145039 turbo seal to exhaust manifold
? exhaust nut manifold to head nut
078103547F valley gasket
078109119J timing belt
078103171 L rear main seal
078 103 181C rear main seal gasket
N 0147392 crank pulley 5mm allen bolt
N90868601 tip flywheel bolt (need 8)
8D0253115F Turbo to Downpipe Gasket (need 2)
078133148E turbo to inlet oring (need 2)
N 90183603 turbo pressure line banjo bolt to n75
N 0138076 tubo pressue banjo bolt washer (need 4)
N 90778701 turbo to downpipe stud (need 8)
N90369001 turbo to downpipe nuts (need 8)
N 0210715 turbo oil feed banjo bolt (need 4)
N 0138182 turbo oil feed crush washers (need 8)
n0147215 turbo to manifold allen bolts (needs 6)
078145757 turbo oil return line oring (need 2)
058145757B turbo oil return line gasket (need 2)
N 0138149 turbo coolant line crush washer (need 8)
078145175B turbo coolant adapter on driver side
N 0138149 turbo coolant adapter crush washer on driver side
N 0210742 turbo coolant banjo bolt (need 4)
078121113F S4 thermostat
N90136802 S4 Thermostat seal
8D0121101AG upper coolant hose to radiator
8D0121055T lower radiator hose
058109229B Cam timing chain
078109244H Cambelt relay roller
078109479E timing belt tensioner
078109243R timing belt tensioner roller
078105229D S4 crankshaft bolt
078109119J S4 2.7 timing belt
059103175A Non return oil valves (need 2)
? main bolts
078115105D oil pump
canyoncarver2
11-17-2008 04:53 AM
jwolf::ASP S3
09-07-2005 10:16 AM
nadrealista
07-14-2005 05:49 AM
?lueshirt
05-11-2002 12:15 PM
