Error Code Help..... Insufficient Vacuum?
It looks like I have a vacume problem. Any ideas were I should start looking? Do these look related?
Thanks Guys for any help!
'17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
P1423 - 35-00 - -
17819 - Secondary Air Injection System; Bank 2: Insufficient Flow
P1411 - 35-00 - -
17884 - EVAP Leak Detection Pump: Malfunction / Insufficient Vacuum
P1476 - 35-10 - - - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
P1423 - 35-00 - -
P1411 - 35-00 - -
Re: Error Code Help..... Insufficient Vacuum?
I'd start by checking the notoriously weak f-hose (see link) and the fuse for the secondary air injection pump (S234).
Then go on to check the other vacuum hoses for leaks running between EVAP canister (aka ACF canister); 'Non-Return Valves #1 and #2 (the two green ones on the passenger side of the Y-pipe air distributor)); and 'EVAP canister purge regulator valve -N80'.
Using your Vag-Com scanner you can run an output test of the EVAP canister purge regulator valve -N80'; Secondary Air Injection (AIR) solenoid valve -N112; and Secondary Air Injection (AIR) pump relay -J299. They are the 1st-3rd output tests on a vehicle with an automatic...you should hear or feel them clicking).
Also, make sure you have a good solid connection from the Pressure Limiting Valve to the Y-pipe air distributor (make sure the o-ring is there and in good shape)...not specific to those codes, but it does throw a few random errors when it doesn't have a good connection.
Please tell me you have an automatic transmission. If you have a manual gearbox, then the 17831 and 17819 are weird codes since only vehicles with automatic transmission are equipped with a secondary air injection system...in which case, your car is miscoded.<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?imageID=3339&html=viewimage.html">http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi/?imageID=3339&html=viewimage.html</a</li></ul>
Jan_PL_S6
08-22-2012 07:45 PM
Excellr-A8
01-11-2008 06:01 AM
Jer
10
12-04-2006 07:31 PM
007TT
04-24-2006 12:28 PM
A4RIP
04-13-2002 03:34 AM
