ETKA OWNERS!! What's the part # for my passenger side 01.5 upright?
I think the pre-1999 B5's had a completely different styled upright. Then 2000 S4's had a aluminum then 01's came went back to steel uprights??? Could any of you ETKA owners out there look up the part number for mine (01.5)?...so I don't have to take a wheel off just to look for the number. TIA!
It's the vertical piece that the tie rod, upper & lower control arms are connected to.
It's the vertical piece that the tie rod, upper & lower control arms are connected to. You know the peice that was made of aluminum on the 2000 s4's but later were changed to steel instead. The wheel bearing is pressed into it. I'm pretty sure ETKA calls it " wheel bearing housing". I'm looking for the right (passenger side) part number. I've included a link with a pic. The part number for the one listed on ebay is for a 1999 A4. I don't know if it is the same for a a 2001.5 S4. I need to know before I bid on this thing.<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7911997880&rd= 1&sspagename=STRK%3AMEWA%3AIT">pic of wheel bearing housing</a></li></ul>
It's for European S4, 82 mm bearings. The rear bearings are the same but the fronts are bigger on S4
This part # has likely been superceeded but will get you close if you call the dealer.
zeems
Audi Original "S" Cars
06-17-2008 01:32 PM
Audi_kraut
03-12-2008 11:34 AM
Luxus Panzer
11-17-2007 03:17 AM
Jason Sowers(rs6's)
08-21-2007 02:31 PM
