ETKA :: power steering hose leak and need an ETKA diagram.
from the power steering pump, there is a high pressure hose that runs under the intake manifold to behind the block. This hose connects to another hose which then runs down below the fire wall (driver's side) and into the steering rack. I've already replaced the first hose (under intake manifold), but it appears the 2nd hose has started to leak. Can the connection to the steering rack be reached from the driver's side through the tie rod access opening?? Thanks for any / all information.
Here is the pic..(sorry about the scaling)
<center><img src="http://pictureposter.audiworld.com/52314/steering.jpg"></center><p>I don't have access to my US ETKA, but the on-line one shows #10 as: 4B1 422 893 BF (for our motor--left hand drive)
I can't find the part on line, but the dealer might have it...
Also, I helped JasonS4 fix something similar. We used an Industrial hose shop to fix the top hose. Only cost $20 compared to the $150 for the part. The fittings are identical. Good quality repair.
cmgossett
Audi 100 / A6 (C4 Platform)
11-29-2004 08:04 PM
