EVAP leak - how do I fix it?
<center><img src="http://pictureposter.audiworld.com/94109/a24-0326.jpg"></center><p>I finally found what has caused Bank 1&2 lean, random and every cylinder misfire, and EVAP leak codes - a slowly tearing hose on the back of the head.
The thing is, I don't know how to replace it, or where to get one!
But it you are standing, facing the firewall, its right under where #9 is in this diagram. And it's the hose on the left.
Any thoughts?
Any thoughts?
do you have a tip and that hose is under the mani ? or just under the Y pipe?
take stuff out of the way until you have access to it.. very simple , but it sounds like you should find someone else to do the job ( good independent euro shop near u ).
Re: a pic in your engine bay would be helpful....
<center><img src="http://img368.imageshack.us/img368/61/s4leaksg3.jpg"></center><p>It's that rubber hose that feels like its wrapped around something. The tear/leak is to the right of the visible white zip tie.
elmsfordracewayinc
11-21-2006 02:25 PM
