Excel's "Save as Web Page" works great for turning log graphs into images....
#12
AudiWorld Expert
fix the scales on my plots? I don't see anything that needs fixing. You mentioned 1000 mBar min is what you use. That happens to be what mine is as well:
<img src="http://ctny.audiworld.com/mark/golf/logs/data/050718_stock/050718_stock_files/Typical-7-18-2005_8-22-37_AM_golf_stock_70ish_8466_image001.gif">
Also, not sure what your issue is with knock:
<img src="http://ctny.audiworld.com/mark/s4/misc_data/knock_output.gif">
Is your problem with VAG and it's timestamps?
#14
of course you could always sort by column whatever...
cool. even though i hate excel i still need to use it so don't mind learning. thanks
#16
AudiWorld Expert
which normally works out well. I like to keep fixed axis min/max values so that I can then immediately notice if the graph is low/high, which *could* be overlooked if the graph is always autoscaling to fit.
When logging the Stock Golf, I expect the boost will be low on the graph, and I'm cool with that. Soon enough it will be filling the graph and I might have to increase the max
![Embarrassment](https://www.audiworld.com/forums/images/smilies/redface.gif)
slo-twitch
09-30-2002 06:28 PM
mattchow
08-28-2001 07:08 AM
