Extreme loss of power and jolting started out of nowhere 2002 b5 s4
Hey, I’m losing my **** working on this thing and need some peoples opinions it’s a 2002 b5 s4.
Out of nowhere the car lost power won’t rev above a few thousand rpm and jolts badly it will get small boosts of power then go back to how it was. I replaced the fuel pump, fuel filter, fuel pressure regulator, and mass airflow sensor also tried another ecu I had in the off chance it had to do something with that. I get an engine light with a p103 code even after the new airflow sensor. I can’t afford to keep replacing random **** hoping something will work, also my daily driver. Any thoughts would be appreciated, to get it running as soon as possible.
,thanks
,thanks
Can you post a diagnostic scan? This data may help identify the fault(s).
For example failing EGT(s) can cause the described symptom.
Have you checked for an intake boost leak? A hose popped off or cracked intercooler can cause this symptom as well.
Best to start with a scan.
,thanks
,thanks
,thanks
,thanks
Bliggity
01-10-2006 12:20 AM
D-Fresh@Curbside
13
02-03-2005 12:44 PM
