F Hose Swap gone bad...................
<center><img src="http://pictureposter.audiworld.com/60037/dscf0543.jpg"></center><p>I had the typical bad F hose symptoms on my 2000 2.7T 6 speed and was replacing my F hose with a samco one. BTW the old one was torn in 2 places in both bends.
I had all of the clamps off and was trying to get the final hose off of the Vacuum hose? The Vacuum hose broke and now I am down and not sure where to go from here.
Is this even a vacuum hose and does anyone know what I need to replace?
I can't tell if there is a sensor involved.
The hose goes under the y pipe and connects to a tri/hose them goes to the y pipe. If anyone has a part number for the part that would be great.
I will probably have to send my wife to get the part and I doubt that she will be able to convey the right part to the parts guys.
<center><img src="http://pictureposter.audiworld.com/60037/dscf0545.jpg"></center><p>The one in the middle.
Thanks!
Thanks!
black plastic material, really brittle? Yea, that crap breaks all the time, especially on the 30 valve V6's(non-turbo). I don't think they're too spendy, and if you're doing your F hose, it'll be an ok DIY for you. Then again, you did break something...... ;-)
Back there by that "spider", there's other vacuum peices that can also be brittle. Be careful!
