Fitting an RS4 clutch/Flywheel into an S4 (1998)
Hi Guys,
I have some part numbers and need to find out if they will fit in my car. I have an S4 from 1998 (I'm in the Netherlands and this is one of the first ones) and the following doner parts from and RS4.
Pressure plate 078 141 123 G
Driving disk 078 141 031 S
Flywheel 078 105 266 S
Will they fit. Does anyone know how I can find out?
Also will there be an advantage to changing the flywheel?
Thanks
Was2103
"When **** gets tough, take a hostage"
Thanks
Was2103
FYI, the pressure plate is the only difference, the clutch disc and flywheel are the same. However, you'll want to replace the clutch disc with the pressure plate and may want to have the flywheel resurfaced, depending on its condition.
-Dave Pramanik
-Dave Pramanik
Well I'm getting the lot for 300 Euro, but it's used. I guess I should fork out a little extra to have the FW resurfaced. The current owner says the doner car only did 40000 KM or so. Should be fine right?
is used and you can have it fitted cheaply( by your self or a friend)then go for it.
If you're having it done by some shop dont do it. The install is too expensive to find out later that the clutch was bad after all.
Funkweasel
17
08-02-2004 09:22 AM
Nogaro Baller
11-11-2002 04:18 PM
Third ROC
9
01-09-2002 03:40 PM
