forge told me to install bpv in reverse manner.
Diaphragm valves do not like pressure holding them onto the seat and then having to open against that pressure to vent it. I am referring to to the pressure that actually has to be vented of coure, not signal pressure.
Otherwise, boost pressure holding the valve shut is something diaphragm valves don't like. The configuration pictured is what's known as a downstream valve.
it will be hitting the diaphragm from the side. So the only thing affecting the diaphragm will be vacuum in small vacuum lines (and, of course, the spring holding it shut)
<center><img src="http://pictureposter.audiworld.com/25380/dv_piston_plot_2.jpg"></center><p>I believe he just had a vacuum pulling on the nipple that is normally attached to the vac lines in the stock config.
-st
-st
