Fornt page Audibmw.com Racing S4...If you guys have any questions
about the car or the setup just ask. I know their are a few other threads started so I figuired it would just be easier to have everything in this one. Thanks Bill III
Great question... The car does have one mounted but
The driver's side bushing has been disconnected ever since I have owned the car. I have hooked it up twice, once at VIR and I almost wasted the car and once in an autocross. With the sway bar hooked up the front pushes really bad in low speed stuff. Contrary to what everyone says coming through the esses at VIR with the sway bar hooked the rear was very, very loose. I do not know if I just completely removed the front sway bar if it would have any negative effect but the next time I am at a non competitive event (autocroos) I will try it. The left front of the bar just kind of hangs loose, while the right side is still connected. So it really should not be functional at all. Just keep in mind that this car has complete solid mounts everywhere. Any small adjustment change makes a huge difference. On a street car when everything is rubber or urethane mounted changes are a lot less noticeable. If you can explain a little more about your setup and have a few questions I would be more than happy to help.
Nepok
09-19-2005 09:59 PM
audiquattroboi
10-11-2002 05:57 PM
Hokie - STI avant
09-23-2001 06:39 PM
