Found interesting post by Bob Lee explaining why Stoptech ST 40s are superior to Porsche Big Reds...
Old 11-03-2002, 07:59 PM
  #41
New Member
964racingS4's Avatar
Default You know the funniest part?
Brembo (for whatever misguided reason) is the supplier of the seals for the stoptech pistons.
Oh, and the reason for the bridge bolt on the Stoptechs? It needs it to keep from flexing.
They should just call 'em CopyTech.
Old 11-03-2002, 08:27 PM
  #42
Senior Member
Auto Union Jack's Avatar
Default I got to drive a APR Stage 3 recently with 332s, but not at a level high enough to discern
superiority. They're damn good, just like the Big Reds on my car. I did notice a more linear feel with my set up, but that could just be 'cause the Reds were on my last 3 Audis and that is what I am used to. I just asked because I know you and Istook are kind of tight is all.
Old 11-04-2002, 06:46 AM
  #43
Guest
Another Drew's Avatar
Default Why does Stoptech ONLY look at piston size?
They're claiming that they're system is superior because the perfectly sized pistons. Yet there's three other major factor affecting braking torque:
1) Radius
2) Brake pad coefficient of friction.
3) system pressure
Stoptech's problem is that the biasing instantly changes as soon as you use a pad that's different from what they used for tuning. Were they using track pads or street pads? What kind of pads were in the rear? What about an S4 with different suspension? These are all factors which change the bias.
And if you have a different brake kit, biasing is easily adjustable by using shims on the caliper to change the effective rotor radius, and using various combination of pads front to back.
Old 11-04-2002, 06:47 AM
  #44
jcrb's Avatar
Default Re: Porsche Had To Build TheMonoblockCaliperOnAllProductionCars From1998 onwards!
>I believe our S4s use Monoblock calipers!
You arre havingk noo klue what you arre talkingk aboutskii :-)
Old 11-04-2002, 06:52 AM
  #45
Senior Member
It's the small guy using distorted marketing hype to splash into market. Consider them exposed.
Old 11-04-2002, 06:57 AM
  #46
jcrb's Avatar
Default You are just making this up arent you?
>The set I puchased,front993tts
from who?
>caused a hard to modulate grabby,unbalanced car >that didnt work with the ABS.
I have 993tt brakes, they have none of the problemts you describe.
>Worst of all,is that most of the vendors selling >these kits knock the 993tts rotors out of >balance creating a very annoying front end shake >so bad,I sold them in a week to my brother.
um how do you know that most vendors do this? heck how the hell do you knock a sold piece of iron out of balance?
>Thats because they are selling their own cob-job >hats.
um, you know one CNC'ed disk of aluminum is basicly the same as another CNC'ed disk of aluminum.
>Movit is the only Porsche kit that works!!!!!>Have deep pockets though!
how do you know?
I think you have no cluse what you are talking about, give us details or go home.
Audone
22
05-18-2007 09:25 AM
ReTodd
01-20-2003 09:51 AM
lordiconS4
11-25-2001 07:50 AM
flaw
Audi allroad
10-18-2001 10:23 PM
Root Down
07-31-2000 10:31 AM
Quick Reply: Found interesting post by Bob Lee explaining why Stoptech ST 40s are superior to Porsche Big Reds...
