Found this today..Need advice
<center><img src="http://pictureposter.audiworld.com/106838/wheel43_kevcpa4_008.jpg"></center><p>Looked over a few things on the car today and found that the Outer cv boot on driver side is torn in half. I cannot not see where all the grease went. Its all clean in there cept for the grease still on the axle inside the boot left over. Should I just replace both outer boots since one is gone?
Also, can I replace only the bushing on the upper control arm? I looked at it and it too is torn/cracked but the arm looks fine. Are the two bushings for the upper control arms the same??
Thanx a bunch.
Thanx a bunch.
You should ideally replace both of those arms on both sides...
...of the car.
Don't mess with pressing the bushes and joints - you'll only be back there later!
Best wishes,
Ram
Best wishes,
Ram
Carlo5555
10-15-2007 07:28 PM
jkid
04-02-2004 03:49 PM
Fanaudical
11-16-2003 09:14 PM
NeverFollow
05-17-2003 06:24 PM
