Front End Bounce
I have been searching on this and have only found limited information on it. When going down the road I have a problem where the front end of my car will bounce or gallop, as it happens multiple times in a row. This only occurs when going over a ridge, bump, etc, but not on a flat surface. So far it seems that it is related to the eibach lowering springs I have on my car causing the problem. I am also running a set of bilstein shocks, making the set. Can anyone lend some advise as to the cause of this and what can be done to fix it?
Possibly related:
https://forums.audiworld.com/s4/msgs/2435628.phtml
Thank you
Possibly related:
Thank you
No thanks to my local shop that supposedly aligned them last time I bought tires 6 months ago... now I'm having to buy another set
Thanks for the recommendation on that... I'll try that first before dropping the cash on suspension stuff... need to replace my toe links also... I found one of them full of water lol
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
to eliminate the copius amounts of rebuilds they have to do every day...chances are, their blown! BTDT man!
and a small/tiny rocks.
If the shock is covered in oily dirt, then it's blown. A little oil on the shaft itself is usually normal.
Anyone have the proper alignment specs for a 2k S4 with edelbrock sport springs??
tt2000
10
02-07-2008 04:00 PM
tberry
08-03-2002 10:03 AM
