Front end shimmer at 75-85mph due to bad alignment?
Smooth until about 75ish, and then gas pedal and steering wheel bouncing a slight bit under the hand and foot. Passenger can even feel it, smooths out at around 85ish. Not tires, since just switched to snows, and same thing.
ideas?
ideas?
Guest
I had similar symptoms.... had tires rebalanced and all is well
My car ran great up to 65 and then went to shaking and 80 I actually had to squeeze the steering wheel to keep it going forward.
Guest
Just wheel balancing corrected my problem.... I had 3 that were off by .5 to .75 oz.
I bought my tires from sears and they tried to balance them 4 times. All 4 times they left me with wheel virbration. I finally went to Goodyear/Gemini and the tech took his time to rebalance the tires.
When he checked them with the wheel weights on he was shocked to see them out of balance so much. Sears put weights all over them chasing the balance. When the Goodyear guys was done with them there was only one to two weights on each wheel and they are so smooth again.
When I first told the Goodyear guy my story he really though a tie rod or suspension component bit the dust but everything was tight.
But I would check there also for any problems.
Hey Dave a "shimmer" is like a "glint"... and a shimmy is what (more)
...you have. Most prevalent problems or issues with front end shimmy are as already noted by esteemed AW'ers... bent wheel(s), balance, tie rod ends, warped rotors, bushings, flat spotted tire...etc...
Rotors have been a frequent culprit...
Good luck.
Good luck.
Steve Trac, Sec 303
19
05-18-2005 09:23 PM
saki76
09-23-2003 05:03 PM
