Front suspension suggestions....
Old 03-17-2006, 08:23 AM
internets's Avatar
Default Front suspension suggestions....
I'm looking to get some coil overs and replace some other parts some as preventative maintenance and some to help with suspension rattles/clunks.
This is my list so far. Anything else I should consider while I've got everything apart? Should I consider buying the hardware kits(bolts and nuts) that ECS offers?
TIA
Vogtland Coilovers $1,109 PureMS
Control Arm - upper right $90 PureMS
Control Arm - upper left $90 PureMS
Control Arm - Front Lower x 2 $220 PureMS
OE HD Tie-Rod Assembly x 2 $190 ECS
Total $1,699
Old 03-17-2006, 08:25 AM
Pat-SoCal's Avatar
Wheel bearings while you're in there? Other than that I think you've got it all.
Old 03-17-2006, 08:28 AM
frank's Avatar
poly frt eng mount , unless he already has it
Old 03-17-2006, 08:30 AM
Pat-SoCal's Avatar
Default Noob!
what does a snub mount have to do with front suspension?
What have you been up to???
Old 03-17-2006, 08:34 AM
quickaudi:STFA's Avatar
Default There any bushings up there? Can't remember...
Other than that, sounds like you'll (obviously) need an alignment after all that work. Make sure to let us know how the Vogtlands work for ya.
Old 03-17-2006, 08:42 AM
internets's Avatar
Default I was considering them...
but MarkP's write up makes it look like *I* wouldn't accomplish it all in a weekend. I guess if I took a couple days of vacation I'd do it.
frank's Avatar
Default get rid of sqeeks and he's already ordering the tranny stabilizer
haven't really been up to anything interesting at all
Old 03-17-2006, 08:45 AM
internets's Avatar
actually the TSB is installed, I'm just too lazy to update my sig picture
WindyCityS4's Avatar
There are 8 fromt control arms, Does PureMS sell all 8 for $400?
Pat-SoCal's Avatar
Default What year is your car?
if you have aluminum spindles it could be done rather painlessly since they bolt-in.
Quick Reply: Front suspension suggestions....
