Fustrated stage 3 owner needs HELP!
My car makes a smooth/sedate 13-14 psi boost at wot in 3rd and 4th gear pulls. I have had the shop check the install twice and everything was fine. A friend and I personally check to see if I have a boost leak but found none. New 710N's were installed but no difference. Vag data, block 003 shows 100% at full throttle, block 115 shows I'm not making enough boost that is requested, block 118 shows duty cycle at 75-77% at 5000 rpm. Anyone knows what duty cycle their stage 3 software is running? I've tried running 100 octane and not much diff in boost levels, maybe 1/2 psi more. Can anyone help? My friend's stage 2 can hang with me and my other friend's stage 2+ just walks all over me....Sighhhhhh.
if they moved that, it could have changed the psi at which the wastegate dumps and it could be opening too early.
Can someone please help me save my VIR weekend, Stage III Homebrew overboosting at WOT like a mofo..
WVA6
11-18-2007 11:11 AM
elijahallen
10-17-2006 07:55 PM
Dr. Back Crackin S4
04-07-2006 05:53 PM
audaciousTT
02-02-2004 04:45 PM
