FYI: me=1, ecux=0
Old 02-11-2007, 08:22 AM
davenew's Avatar
Default FYI: me=1, ecux=0
I bought a new laptop to use with ecux and logged with no problems but never tried to change the settings. After having data dropped yesterday I tried to reduce the baud rate for logging today.
After opening an ecux group file I tried to click "actions" "settings" and got a run time error stating I need to load MSSTDFMT.DLL. WHen I clicked OK the program closed.
I copied the dll file from my other machine and pasted into windows/system32 but got the same error message.
I searched the net and found some advice to get it to work:
http://ask-leo.com/msstdfmtdll_is_missing_where_do_i_get_it.html
"That being said, you may already have the file on your machine. Use search for files to find it. If it's found, you may be able to get things to work by executing ""regsvr32.exe msstdfmt.dll" in Start, Run."
I typed regsvr32.exe msstdfmt.dll into the start/run box and opened ecu again..
ECUX WORKS!
I think this one of the very few times someone has solved a problem with ecux without emailing or shipping thier laptop to apr! J/K
I'm using a dell latitude P4/1.8Ghz with 512MB ram. WINXP pro
BTW, my baud rate was set at 57600 by default and I justs reduced it to 19200.
Old 02-11-2007, 08:38 AM
SmokinS4™'s Avatar
Default why'd you reduce baud rate to 19200?
I remember my first 300baud modem/phone coupler....nerd history =)
Old 02-11-2007, 09:56 AM
FixedWing's Avatar
Default Evidentally the serial chip cannot handle the higher rate without dropping data.
Cheap **** laptops. :-p
Actually, in days of the first personal computers, it was often necessary to replace the serial chip to cure this problem.
Stephen
Old 02-11-2007, 10:16 AM
reefer_bob's Avatar
are you using a real serial port, or a usb and emulator?
Old 02-11-2007, 10:24 AM
davenew's Avatar
real serial port
Old 02-11-2007, 10:46 AM
box_of_partS4's Avatar
Default Hey man, Dave and I got ECUx working on his car (he called you on Friday, it was my copy of ECUx)
We had to restart the car. ECUx wouldn't communicate with his ECU until we did that.
It's strange, because on my car, I always plug in the cable after the car is already running, then run ECUx, and never had a communication problem.
Old 02-11-2007, 10:47 AM
Default That's interesting, mine must be fine...I use the serial port on my Dell 600m to log at 57600 baud
Dell must have used some cheap stuff in the Latitudes =)
Old 02-11-2007, 11:33 AM
DxC
DxC's Avatar
ECUx seems so finicky, i wonder if this alleged "version 2" will ever come out
Old 02-11-2007, 11:46 AM
Mike2kS4's Avatar
Default They should include MSSTDFMT.DLL with the installation package.
I ran into that one and did just what you did.
Good call on the baudrate. How did that affect your sampling rate?
Strange thing is, my old Inspiron 9100 933/512 had zero problems with ECUX on serial with everything at full acceleration. Now I'm using a 933/512 Fujitsu tablet.
Old 02-11-2007, 11:56 AM
Junior Member
noSup4u's Avatar
must be old to not have a 16550 uart
Quick Reply: FYI: me=1, ecux=0
