Getting a "check engine" lite and "ABS" lite w/ new chipped ecu ?
Ok my car isn't getting any smoother after 100+ miles w/new abt chip and giac Tip chip installed yesterday. I did the 3-5min "key-on"TBA after installing. Car still surging under medium to heavy throttle, particularly when it shifts.
Should the boost drop off momentairly for each shift of a Tip?
Check engine lite came on after about 80 miles and now the ABS lite comes on under heavy acceleration in top gears. Any ideas on ABS lite?
I just ordered a VAG, 710N TT Bypass Valves, and ABt TBB. I'll do a VAG TBA and then get the fault code I guess? and then install the new parts?
Does this make sense? TIA
'02 Tip Greenhorn
'02 Tip Greenhorn
for a couple of days and hope they give you something that works and is not slower this time
algisas
Audi 100 / A6 (C4 Platform)
11-21-2005 07:45 AM
Ok, have the VAG hooked up to my car with the ABS light on. Can't connect at all with the ABS proble
S4Del
12-12-2003 04:23 PM
2fastS4
08-18-2003 10:46 PM
