GIAC AWE requested boost question
Here is my requested log from the Atlanta dyno day of my AWE stage 3 setup. There is a broad trough from 2500-5500 RPM. Is this part of the programming or is the ECU backing off because of feedback from the knock sensors? At WOT it should be open loop for the O2's right?
<img src="http://www.flwse.com/images/steve/Audi_Tech/ECUx/4runs_compare_graph_rob_files/4runs_compare_graph_12292006_18259_image003.gif">
Here are <a href="http://www.flwse.com/images/steve/Audi_Tech/ECUx/4runs_compare_graph_rob.htm">rest of my ECUX plots</a>
Thanks for any comments.
it looks like its the programming. I haven't seen an stage III log in awhile but you look pretty on par to what the other people out there have for requested boost.<ul><li><a href="http://www.flwse.com/images/steve/Audi_Tech/ECUx/4runs_compare_graph_wade.htm">Click!</a></li></ul>
<center><img src="http://images19.fotki.com/v365/photos/8/85931/4500366/_p0t_vs_p3t_40f_29519_image002-vi.gif"></center><p>
here is mine from last week.....very similar dip then climb. It is the programming/file itself
I ordered the "parallel" version from Vast because the description talks about "closing the bleedhole" for use with N75. I figured with this version I could use it either way, but I don't think the one I received has a bleed hole at all.
Is this a modification I can make myself?
