GIAC + MBC in Parallel installation dilemma.. (long)
#21
The reason I prefer MBC in parallel is that in this setup, the MBC will only *change* the initial boost spike. When you reduce SEL scaling, the entire boost map is changed (requested boost moves down).
#24
You can't lemmi off the top of an overboost curve. BUT you can MBC it off
Also, the most serious K03 chipped spikes (ones that lead to instasplode) don't happen every time you prod the pedal. You could set your MBC to 17.5psi and it might only actuate once a week or so! I suggest between 16-17# for best timing, though.
#27
With that said, I prefer MBC in parallel because of what Mike and I have explained here with it reducing the entire boost curve instead of just the spike.
#28
If you don't mind the across the board cut in boost then you could do it the Lemmi way, but to maximize performance, add the MBC.
