Going Crazy!!! I can't figure out these damn fault codes. Thought it was a bad wire on O2s but no!
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17938 - Camshaft Timing Adjustment: Short to Ground
P1530 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-00 - -
17523 - Oxygen (Lambda) Sensor Heating: B1 S1: Short to Ground
P1115 - 35-00 - -
17527 - Oxygen (Lambda) Sensor Heating Circuit: B2 S1: Short to Ground
P1119 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-00 - -
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-00 - -
P1425 - 35-00 - -
P1530 - 35-00 - -
P1547 - 35-00 - -
P1289 - 35-00 - -
P0102 - 35-00 - -
P1453 - 35-00 - -
P1457 - 35-00 - -
P1115 - 35-00 - -
P1119 - 35-00 - -
P0134 - 35-00 - -
P0154 - 35-00 - -
sergeyk
12-06-2008 12:16 PM
PKmode
09-25-2006 10:53 AM
PKmode
09-21-2006 08:09 AM
BLK01S4
15
08-02-2005 07:44 PM
sissupr
05-20-2003 08:26 AM
