is it a good idea to change the water pump and timing belt at 60000 miles?
...the timing belt isn't the easiest thing to get to.
Remove front bumper
Remove radiator assembly (or at least get it out of the way)
Remove harmonic balancer and main belt
Remove the 3 covers (dust shields for the timing belt/pulleys)
Set the engine (TDC on i believe cylinder 1)
Loosen the timing belt tensioner
Replace belt (while you are at it, check the indexing on the cam pulleys to make sure they haven't moved at all)
At this point, yanking the water pump is probably pretty easy, though I can't say I've ever done that before.
Installation is in reverse.
Need to be careful with the timing belt in an interference engine such as ours. Better to replace the belt regularly, than break the belt and cause some serious damage.
Not sure what the longevity of the water pump is, but every 50k miles sounds like good practice for the timing belt and water pump. I'd add the fuel filter to the list as well.
Remove front bumper
