got a misfire last night that goes away after about a minute or 2. heres my codes...help!
10 Faults Found:
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
16805 - Shareware Version. To Decode all DTCs
P0421 - 35-00 - Please Register/Activate
16815 - Shareware Version. To Decode all DTCs
P0431 - 35-10 - Please Register/Activate - Intermittent
17837 - Circuit for Brake Vacuum Pump: Open Circuit
P1429 - 35-00 - -
18320 - Shareware Version. To Decode all DTCs
P1912 - 35-00 - Please Register/Activate
18058 - Shareware Version. To Decode all DTCs
P1650 - 35-00 - Please Register/Activate
17862 - Exhaust Gas Temp Sensor 1 (G235): Short to Ground
P1454 - 35-00 - -
17866 - Shareware Version. To Decode all DTCs
P1458 - 35-00 - Please Register/Activate
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16689 - Cylinder 5 Misfire Detected
P0305 - 35-00 - -
I then clear the codes, start car, and p1649, p1650, p1429, p1458, p1454, p1912 all come up again...
any thoughts on where to start?
P1649 - 35-00 - -
P1429 - 35-00 - -
P1454 - 35-00 - -
P0305 - 35-00 - -
This is because you dont have the full version of VAG-COM.
P1429 - 35-00 - -
This code is there because you have a 2000 S4 and your ECU is probably a 2001 or 2001.5 ECU with ESP for some reason and since you dont have ESP that codes shows up.
P1649 - 35-00 - -
You need a New or Rebuilt ABS module
P1454 - 35-00 - -
You need a new EGT sensor, also check the connection could be that & the misfire could be anything.
P1429 - 35-00 - -
P1649 - 35-00 - -
P1454 - 35-00 - -
b5s402
18
07-24-2007 06:14 PM
nt2old4ns4
Rocky Mountain Discussion
9
06-30-2007 06:18 AM
