Got a question about Lemmiwinks and timing advance, has anybody tried to advance timing
on a stock car 1 or 2 degrees? Can it be done, and what would it do to the performance of the car? And how would this advance compare to the old way of doing it as a permanent fixture with the cam gear? I can always buy 93 octane, so gas is on the good side.
Adv timing is allowing the spark to happen sooner, changing the cam gear position changes when the valves are open.
You sould be able to do some slight changes with fuel and timing on a stock chip.
far it can go, and if it gets any faster. I'm betting it will meet requested load with less boost and not be any gain except off boost. +3 does feel good off boost though.
so if you were willing to take it to the edge, you could probably pep it up a tad... but really, you wont see many gains w/o upping boost like you said.
i'd be curious to see the numbers on 93/94oct..
in cali with 91oct, cyl5 would almost get into the danger zone on a HOT day, even with a stock ecu.
I just checked voltages real time, knock may have been ~11-12v stock stock on BP 93. didn't look at CF.
I need to nab it for an hour or so and do extended logging/tweaking. Nothing I saw looked dangerous, and most mid range stuff had very low knock values. Biggest difference I noticed was sub spool torque, it'd really take off.
BlackS4tt (Josh)
42
10-04-2006 04:07 PM
zapco98
29
04-08-2003 02:25 PM
LCP
05-24-2001 10:49 AM
27t, advance, advancing, apb, audi, boost, correction, factor, lemmiwinks, off, timing, unisettings, vtune
