Hartmann B7 19" RS4, +42 offset, 255/30/19 tires...will it fit without rubbing?
I have searched here and on AZ and have only found a small number of posts where people have gone this wide on a tire.
I may have a deal on the above since summer is ending and the seller wants to get rid of them.
I am on stock suspension and have stock brakes. I have no plans to change either.
My question is can I go with this wide a tire without rubbing?? I don't want to roll my fenders or anything.
Thanks for your help...
Will likely need spacers to clear inside struts. Will likely rub on severe cornering. Probably OK
for cruising. Rolling is not that hard. Don't let that hang you up.
Bruce
Bruce
You will need the 242 high clearance to clear a HP2 caliper ET35
Spacers are not really a option, by the time you get past the caliper you won't be on the hub anymore.<ul><li><a href="http://www.Hartmannwheels.com">http://www.Hartmannwheels.com</a</li></ul>
SpeedCrazie
09-24-2010 08:52 AM
