has anyone blown a fuse here? my cig lighter wont charge my cell phone....
after i installed my V1, i cannot get my cig lighter to charge my cell phone with the car charger. futhermore, when i press into the lighter, it wont pop back out, meaning it for sure is not getting any power.
any ideas what to do? i havent dealt with any fuse issues with this car. TIA
my VDO gauge and V1 are in the same fuse slot. is this a good idea?
stupid'ist question of the day, how do i change the fuse for my cig lighter? what number is it, any pics of which one i have to change out?
thanks B!
thanks B!
or use the special audi fuse puller on the fuse pannel.
Which number did you use for the VDO and V1? I have my VDO and V1 tapped onto the x75 post under the kickpanel - no problems so far.
<center><img src="https://www.audiworld.com/tech/pix/audiv1.jpg"></center><p>i currently have my VDO power and V1 power going into this slot. according to this pic, #27.
where should i put the new fuse?
sorry for the dumb questions, never did this before.
black debris. Change it with the same rating: 15Amps.
I wouldn't recommend replacing it with a higher fuse. It may melt something or cause a fire down the road.
Make sure that there is no contact between the jerry rig you put into slot 27 and the frame of the car (ground) as that will certainly blow fuses.
can make some part of the wiring the weak link.
There is not a chance in hell his cell phone is drawing 1 AMP, let alone 20 or more.
Mike S
Mike S
