Have any of you seen this fault code before?
Control Module Part Number: 8D0 907 551 M
Component and/or Version: 2.7l V6/5VT 01 0002
Software Coding: 06611
Work Shop Code: WSC 91445
1 Fault Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
Control Module Part Number: 8E0 614 111 A
Component and/or Version: ABS/EDS 5.3 QUATTRO D10
Software Coding: 0273004284
Work Shop Code: BB 24334
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
I went over a decent pothole today (damnation) and as soon as I did, this code popped up and the ABS light came on. Any idea what the deal is? I'm assuming the electrical harness came off the sensor when the car hit the bump, but I'm not sure if that's even a possibility. Thanks for any help.
1 Fault Found:
1 Fault Found:
PhunkFX
38
12-07-2008 03:29 AM
