Have you guys seen this fault codes before? My car is not running! Need help!
This is what codes I found from the engine:
9 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
18320 - Pressure Sensor for Brake Boost (G294): Short to Plus
P1912 - 35-00 - -
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
17837 - Circuit for Brake Vacuum Pump: Open Circuit
P1429 - 35-00 - -
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-10 - - - Intermittent
17931 - Crash Signal from Airbag Controller: Implausible Signal
P1523 - 35-00 - -
Readiness: 0110 1101
Have you guys seen these codes before? What can I do to fix them? I can not drive the car normally. It moves around, but only up to 5mph. When I step on the gas, there is no response. The car can only be revved up to 2100 rpm if it's in Park. Any ideas????
9 Faults Found:
P1650 - 35-00 - -
P1559 - 35-00 - -
P1649 - 35-00 - -
P1912 - 35-00 - -
P1118 - 35-00 - -
P1429 - 35-00 - -
P1523 - 35-00 - -
ok, found out the problem. My throttle body is BLOCKED. I had to remove the TBB and found out what was blocking it.
Now the car is running well. Thanks for the inputs!!
BrokenRocket
02-02-2006 01:48 PM
Cargasm2.7
VAG-COM Discussion
10-07-2004 12:43 PM
RageRacer
08-10-2003 09:19 PM
