Hawk pads don't utilize the wear sensors correct?
do you maintain your own vehicle (service-wise)?
if you check your brake regularly, you can cut the connector from your old pads, twist the wires together and plug it in. Zip tie it to the upright out of the way.
Everybody with big brake kits or most non-OEM pads does something similar to this.
Just check your pad wear every 6 months.
