headlight bracket fixed.. but we'll see how long it lasts.
<img src="http://dave-new.com/S4/headlight_bracket/DSCN0877.JPG">
<img src="http://dave-new.com/S4/headlight_bracket/DSCN0879.JPG">
BTW, the new headlight bulbs are brighter than the old ones!
Oh, and as for the bulbs, told ya so.
Now that you can see, properly aim your headlights, since you took them out, and you'll really be amazed.
ModifiedA4.com has a GREAT writeup.
what did you do there? used a metal plate and screws to hold the 2 together, and a bunch of jb weld/gasket stuff all over?
I replaced valve stem seals on a 1.5L '93 tercel the other day and the $15 harbor freight valve spring compressor legs were too wide. The dremel came in very handy to make it work. Everyone should have a dremel in their tool box.
Yea, the plastic was cracked mid way up the tab. The two screws are on opposite sides of the crack. The RTV is on there to hopefully make the whole thing stronger. I used some old aluminum brackets I've had laying in the garage for years..
