Headlight Fault Code
I keep getting a headlight fault code that keeps coming back right when I clear it. Anyone know how to fix this?
01539 - Headlights Not Adjusted
35-00
It's in Adtress 55.
35-00
It's in Adtress 55.
Follow step #7 in the tech section.<ul><li><a href="https://www.audiworld.com/tech/misc29.shtml">https://www.audiworld.com/tech/misc29.shtml</a></li></ul>
Procedure for Aligning Xenon Headlamps:
[Select]
[55 - Xenon Range] (For some newer vehicles, use [29 - Left Light] instead )
[Basic Settings - 04]
Group 001
[Go!]
Wait at least 20 seconds for the headlamp motors to move. The headlamps are now in their adjustment position. Turn on headlights. Adjust them via their manual adjusting screws as referenced against a suitable aiming target.
Scroll up to Group 002. The Xenon Range controller has now learned this position as its Home position.
Click the [Done, Go Back] button and you're all set.
Note: There have been reports of lowered vehicles displaying an error message in either Basic Settings group 001 or 002. If the vehicle height sensor(s) are bottomed out, it may be necessary to bend the sensor bracket to allow normal adjustment to occur.
[Select]
Group 001
[Go!]
JoePGT5S
12-10-2017 02:27 PM
SteveMondragon
VAG-COM Discussion
01-25-2006 07:30 PM
