Hearing a blow off valve sound when letting off throttle, replaced BPV's but still makes the sound!
Old 09-19-2006, 10:31 AM
Z-Tuned (Alex)'s Avatar
Default Hearing a blow off valve sound when letting off throttle, replaced BPV's but still makes the sound!
I had 710N's for a while and I started to hear a blow off sound when letting off the throttle coming from the passenger side of the car (I can distinctly tell it's the passenger side area). So I put the stock 710As back on which are NOT broken but the BOV sound still occurs.
It feels like the car is not pulling as hard as usual, but it could just be in my head. What can cause a BOV sound besides bad BPVs?
Old 09-19-2006, 10:32 AM
Also, I don't know if i'm making full boost, I will have to hook up a gauge. Would a leak cause it?
Old 09-19-2006, 10:34 AM
Member
Mike@StartupRacing's Avatar
Sounds like a boost leak.
Old 09-19-2006, 10:41 AM
eigenvector's Avatar
Default leak!! my car is like that right now !! no one can find the leak tho :(
took my car to mechanics used smoker cant find.. i pressure tested cant find.. it just came back from stage 3-... my vac is 14 and max psi is 14. sigh
Old 09-19-2006, 10:52 AM
mtaesch (Matt T)'s Avatar
when my Throttle Body Boot ripped it sounded very similar to a blow off valve
Old 09-19-2006, 11:13 AM
Nogaro 2.7t's Avatar
Default DVs
I had the exact same thing and it was my diverter valves
New Member
booobS4's Avatar
i have that sound everytime i step on my gas and then boost a little and let go and it makes a noise
Old 09-19-2006, 11:41 AM
Hogothorpe's Avatar
BPV = DV
Old 09-19-2006, 12:28 PM
Where are you hearing the blow off sound? mines passenger side, airbox area stock....
Old 09-19-2006, 12:44 PM
BeeRock::Riding Red's Avatar
edit: turbo outlet leak? I meant s4 motion, yours sounds like blown dv's mine was like that
Quick Reply: Hearing a blow off valve sound when letting off throttle, replaced BPV's but still makes the sound!
