heatsink for oil filter - hit/skip?
#14
I see few potential problems where it wouldn't work as well as claimed if:
1) contact surface area between the filter and the heatsink isn't large and good. It could actually work as a blanket if the contact isn't good.
2) If there's little air flow around the filter, it doesn't do a lick of good. Plus the air flow over the fins would have to be in a good direction.
#17
you do have air from the side grills getting through there. I'm not sure how much actually flows around, near, etc. the filter. I think the bottom line is that someone needs to try it and do some logging.
But it could work in the right environment.
-st
-st
#19
I wasn't saying that the contact surface isn't large. What I was trying to convey is that good contact area is critical.
I was picturing the side profile of the filter not being flat in order to mate up with the sink well. I was also picturing any little dirt creating a short gap, but creating a significant pocket of non-contacting surface area.
Either way, even if it works well, I can't imagine it being an oil cooler that makes a significant difference when compared to the heat our engine makes. On the other hand, I can't imagine it harming our engine either even if it acts as an insulator.
