Help APR ECUx -perts needed! If I have a 551T box but with M Code what property file do I use?
As far as any scan tool will be concerned, you have an M-box ECU. The code on the chip is effectively the only difference between the various ECUs (at least as far as 6-spd ones are concerned... I don't have any experience with tiptronic ECUs).
Does this mean that you've got ECUx working? If so, congrats! :P
-Dave Pramanik
-Dave Pramanik
AudiWorld Expert
Certain ECUs are similar enough that they will still make connection, etc, but if you are using the wrong proprty file, the data will all be constant. Might not be all variables either. It'll start logging, and if you start moving, you'll notice nothing changes. Just wanted to mention that so if people see this happening, it's a sign that they are using the wrong property file.
Since I could not connect and get ECUx working I still have no idea what I am supposed to see.
